No really, it is! I've been thinking about this for a while and have finally got around to making it. I work a lot in occupied homes and space is always tight. An MFT is a non-starter for me, and sometimes even a B&D Workmate is too big; often I end up using a systainer to rest on, with the workpiece literally held in place - not ideal.
What I needed was a small, flat surface, maybe with holes in that I could clamp stuff onto...
[attachthumb=#]
Maybe the same height as a Sys1, so I could use it on the floor if I needed to and have support either side...
[attachthumb=#]
And made to slip over whatever stack of Systainers I have with me to make an impromptu bench.
[attachthumb=#]
Obviously it's only for lightweight work, but it's surprisingly steady (once the stack's off the roll-board, or course!) and very flexible - need it higher, just add another Systainer to the stack! Overall size is 500 x 600mm, and the whole thing's made from 18mm MDF (offcuts and scrap, took me about an hour); the sleeve that slips over the Systainer is just glued and screwed together, and fixed to the top with glue and dominoes - though I had such a fight taking it apart after dry-assembling it, you have to wonder if the glue is really necessary
Anyway, works for me; might work for you too!
Cheers, Pete.
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
Cheers, Pete.
