I would caution against ordering this: I followed the instructions exactly; unfortunately they are incorrect. First: If you use his measurements for attaching the clamp to the bottom you will end up drilling right through the miter slot. With the in-feed table flipped over the slot sits 1-5/8 - 2-5/8 from the edge, NOT 2"-3"! Second: The wrench you need to tighten the clamp is 13mm, not 12mm as stated. Finally I own a SawStop cabinet saw, and purchased that model but this does not sit flush with the top. So now I need to figure out a way to shim this. Extremely disappointed with this as I now have 2 holes right up through the miter and it doesn't fit well. I did see others have the same issue as I had - so this product has changed from when the instruction video was made - which are the only instructions that are available as none came with the product
