ear3 said:
There was no offset on that final cut, but just set to cut right up to the line -- machine calculates what to do once it gets into acute corners like that so that it doesn't move outside the cutting area, so there ended up being more hand work to do to square off the corners than there would have been if they were 90 degrees.
Thanks [member=37411]ear3[/member] for that info...interesting to know the amount of machine intelligence that's incorporated in the Shaper. [cool]
But those corners and the shape of the butterfly is soooooooooooo much nicer than a simple 90º corner. [thumbs up]
True story, when I did this countertop about 2 years ago I was going to place a couple of "your style" Ebony butterflies in the gap on the LH side. However, lacking a Shaper and the tooling/fixturing I needed, I just decided to move on without them. I tried to keep the task as a home improvement project and not turn it into a science project. [smile] I also didn't want to hack up and destroy a 200 year old chunk of white oak. If I had the Shaper back then it'd probably have been a different story.
[attachimg=2]
