Jessem Router Table Build Out
GregInVa
I picked up a Jessem Ultimate Excel router table back during the holidays. The one with the side lift handle. I've been working on enclosing the stand and building out some storage underneath to store bits and accessories. I have the Jessem dust box and I'm finding it's so wide there's not much space on the sides to add usable drawers. I'm putting a large drawer under the dust box but drawing a blank on how to take advantage of the available space on the sides.
If anyone has any suggestions or can share some pictures of a comparable build I'd be appreciative
Here is my router table build using Incra products.
Solid looking build [member=70363]MikeGE[/member]
After five years, how's it holding up? Is the CleanSweep performing as well as expected? Any issues with dust buildup inside the CS or causing issues with the router motor or Wixey electronics?
Thank you, @onocoffee! So far, I don't have any complaints about the router table. The CleanSweep box and insert rings perform as advertised. After a few hours of use, there is a little build up of dust/chips in two corners of the box, which I can't explain, but the combined amount is less than half a cup.
After the first two years, I removed the router motor to check the brushes, and was pleased to see the inside was clean. The brushes still looked new. Likewise, the sensor strip on the Wixey is spotless.
If I was starting over with a clean slate, I would build the same router table with the same components. They just work flawlessly.
I have an Elektra Beckum TF-904 shaper (spindle moulder depending on which side of the Atlantic you are on) and Robland RAV-32 power feeder for future larger jobs.
[member=70363]MikeGE[/member] that's a great looking build. The problem with the Jessum table is the dustbox is so wide, there's not much space to put drawers alongside. Using 1/2 ply for support there is less than 4" to attach a drawer.
[attachimg=2]
I was wondering about this and was thinking maybe one could only use that space as kind of a side cabinet, which one would access from the left side rather than the front. But back to basics - how did you attach plywood to the legs and bottom? The base doesn't have convenient holes for bolts. Did you drill through the steel?
