Here are some pictures of the NAINA Basis 4 insert. I wanted to be able to use my PS 300 in a table mount, and the Basis 4 part was the only solution that didn't add a plate between the jigsaw base and the work.
I didn't buy an entire Basis frame. I thought about cutting into the MFT to install the insert, but it is large and would have removed too many useful holes. Instead I made legs for it.
The insert was not modified in any way. The legs are made from 5/16-18 threaded rod and fasteners. The wood bases are simply clamped onto the MFT.
[attachthumb=1]
[attachthumb=2]
[attachthumb=3]
[attachthumb=4]
[attachthumb=5]
Incidentally, the pictures show the S155/W knife blade (493656). This blade is for soft materials such as foam rubber, insulation, soft plastics, leather, and paper towel rolls. Bosch makes a small straight knife blade, but the Festool one is better. Unless your dealer carries every blade, they probably don't have this one in stock, so I suggest ordering a pack. You'll be able to cut materials you couldn't cut otherwise.
[attachthumb=1]
[attachthumb=2]
[attachthumb=3]
[attachthumb=4]
[attachthumb=5]
