First post so, first things first. Hello. I am a newbie wood working hobbyist. At most, I have about 6 hours per week I can spend on this new hobby.
I have a tiny one car garage which is slowly getting converted into my woodshop.
I have a TS55 and an MFT. I've been building a storage bed for my kid. Its essentially 3 cabinet carcasses that come together to form a platform style bed. Building the carcasses has been, more or less, straightforward.
As far as I can tell, the TS55 and MFT combo cannot do the following very well:
I think the dado and the rabbet can be solved by using a router. However, the ripping of narrow planks seems to be solvable only by quite a bit of acrobatics using scrap pieces of wood and the TS55 with a guide rail.
As such, I was considering getting a small table saw. It seems that a table saw can be used to efficiently do dados, rabbets and ripping narrow ish boards.
I was considering a jobsite size table saw as they are the most friendly to the amount of space I have to work with in my garage. I went to a sawstop dealer yesterday to have a look/see on the upcoming sawstop jss. I notice that not only is the width of jobsite saws considerably smaller than say a comparable contractor say, they are considerably less deep (from front to back).
Now, to my question. Do those who use jobsite saws find the depth of those saws to be a challenge as compared to something like a contractor size table saw? For example, do you find them to be more difficult to get consistent and repeatable accurate cuts? Do you find that they are limiting in terms of what you can use in terms of things like cross cut sleds?
Thanks in advance.
- Dado
- Rabbet
- Ripping a narrow plank into multiple narrower planks. For example, ripping a 4.5" wide board down to 2 2" boards.
Thanks in advance.
