If you need a quick method for connecting two guide rails follow these easy steps. There is also a step-by-step pictorial below for your reference.
1. Using two guide rail connectors (482107, sold separately) join the two guide rails to one another.
2. Using your TS plunge saw, bridge the two guide rails by centering the saw on the point where the two rails meet. Using the saw's green guide rail alignment knobs, tighten the saw onto the guide rails so there is no play and the saw does not slide.
3. Tighten the set screws on the top side of the guide rail connectors.
4. Slide the guide rails over the edge of your MFT, being sure to support the weight of the saw, and tighten the set screws on the bottom side of the guide rail connectors.
5. Remove the saw from the guide rails by loosening the alignment knobs and tighten the screws on the guide rail connectors that were positioned underneath the saw. Be sure to re-adjust your saw's guide rail alignment knobs to minimize play while allowing for easy sliding.
6. For added peace of mind, check the alignment with a high quality straight edge.
