Peter Hamilton-Scott
- Sep 20, 2009
Today I joined two guide rails using the interlocking bars. I noticed that there was a little bit of movement where the two rails come together. That got me thinking that if I cut along the rail there might be a slight angular error where the saw transitions from one rail to the next at the point where they join. True, the angular error is very slight but if, as a purist, I want to ensure the cut is absolutely as straight as possible how would I do that?
I tried using a third rail's edge and aligned the two rails I was joining against it and that seemed to stabilise the join before I tightened the screws. Is there a better way of ensuring a direct transition from one rail to another that you can suggest? I know my idea is practical but perhaps you have other suggestions?
