Chris Rosenberger said:Looks very nice.
I would have liked to seen how the put the knots in the spindles.
How big is the opening in the risers?
Thanks Yes it Douglas fir , The tread mounting that that I use is really simple 3" X 3" angel brackets,here is some picturesSparktrician said:Very nice!!! Douglas fir? What is the tread mounting system that you used? I really like the spindles.
[smile]
Thanks What I mean simple is, to what I had to build at this one log home. It was bit complicated compare to this stair case.woodguy7 said:Those spindles are cool, i really like them. I also like the shadow gap at the ends of the treads. No such think as a simple set of stairs, not ones that look like that anyway.
Nice one,
Woodguy
Thanks.Top Knot said:Both stairs in this thread are very very nice!!! I cant say I like the metal angle iron idea for the straight stairs. What was the reason for attaching the treads in this way when it almost seems as though the very idea for using such CHUNCKY pieces of wood for the Stringers and Treads is to say: "This is a Timber Staircase with a statement!"
For the curved handrailing did you laminate it around a Jig or did you use the staircase itself?
Thanks for sharing
woodguy7 said:Eduard, after it comes off the clamps, how do you shape the handrail ? Is it all done with hand tools or some power tools ?
Cheers, Woodguy.
Ken Nagrod said:Isn't that the chinking you're referring to, JMB?
