I'm giving some serious thought to the Kapex 60 and have two questions that I'm hopeful some of you may be able to answer.
1 - Does the Kapex come with 4 holes in the base so I can bolt it to standard Mitre stands?
2 - Does the LED shadow light shine through to the wood when the blade guard is in place, ie can I line up my cut without having to lower the blade to remove the blade guard to show the light.
With lasers this is easy but I've used the Dewalt and you have to lower the blade to see the shadow line which makes the system pretty redundant as I might as well just lower it onto the wood.
