Kapex Aftermarket Infeed table
jgelman
I just upgraded to a Kapex.  This will be used in a home woodshop and will not be taken to job sites.  I really do not need extremely long infeed and outfeed tables as I once had that with Biesemeyer and they were very nice, but they took up way to much counter space, and I now have a very large combo saw that can handle long pieces nicely.
I was planning to build a stand for it on casters with room for the dust collector below the saw.  I was thinking of building a wider stand and mounting an indeed table to the saw.  I was told that the one that telescoped is being discontinued.  What I did not like about it was that the stops seemed flimsy.  There was another infeed table option with a wider base, metric only that did not telescope.  What I was wondering is if anyone has any experience with a nice aftermarket infeed table that telescopes and is extremely accurate with inch/metric measurement options?  I did a search but could not find any information on that.  Thanks.
My kapex is typically dedicated to my woodshop too.  I have 17 feet each side.  I spent $14.00 on a sheet of 3/4 laminated MDF and made the outfeed tables.  I don't have a picture of the right side but I support the lumber on on a box that sits on top of my jointer.  I only have 72 inches of repeatable fence on the left side.  Nonetheless 17 feet each side seems to be enough for what I do.  You mentioned a telescoping system, this is fixed and may not help but it may give you an idea.  BTW, I use the Kreg fence system.  I bought the system in separate parts and the first four feet is seemless, I didn't want a joint every two feet.
