LDBecker said:
I think both of your set-ups illustrate the problem I am having. I am trying to, for example, cut several long pieces of wood, 4-5' in length. When cutting long pieces, they can't rest against the back of the wings because the auxiliary fence, in my case, is 3/8" wide. If I bring the wings' backstop flush with the backstop of the wings, I can no longer move the fences (with the aux wood pieces) to the left or right - in case I had to cut at a bevel. The Kapex's fences no longer line up in a way that lets them slide past the edge of the Kapex.
Do you not need to slide the fences farther away from the blade from time to time?
Thats what both Edward and Erock are getting at regarding the wings.
I do the exact same thing my self and I always leave the wings set back.
There is no need whats so ever to have the wings flush with the fence apart from being a pain in the arse and actually be dangerous.
If your timber in bent the wings get in the way. The only place its important for the timber to seat correctly is on the kapex fence and not the ug wings. If you do set the ug wings flush and have bent timber you then have to make sure the curve is away from you. If not the timber can be slightly away from your fence and as you cut it will bend towards fence causing your blade to bind and then BANG!
