Creativemike
- Feb 25, 2019
I have started to notice when I pull the trigger to pull down the motor of the saw, it is getting stiff and literally impossible to move down. I have tried spraying LPS1, blowing it off, etc. and after that it seems to work for a while and then get stuck again. It appears to be something going on with the bearing that rides around the plastic shroud around the blade itself. Something is getting stuck and it’s not allowing the head of the saw to free flow down. I don’t want to start taking this apart and get it to a point where I can’t put it back together again and I will be forced to send it off to festool. Because of Covid, I can’t just drop it off and would need to pay likely a few hundred in shipping alone. Has anyone else experienced this issue and if so, how do you fix it? Thanks
