Knipex Pliers -- Made in Germany -- High-End Quality Tools
Yes, I've recently become somewhat hooked on Knipex pliers.
Someone has just brought this to my attention: NWS Slip-Joint Pliers, also made in Germany.
I Googled and found this:
Knipex also makes a ratcheting pliers wrench that I've grown quite fond of.  Smooth wrench jaws that don't mark up the surface of whatever you're working on.  I've been using a friend's pair, but am hoping that Santa leaves one under my Christmas tree [big grin]
Interesting. Very clone like. It is a toss up on the thickness. Depends on the steel quality as to which is stronger. But Knipex uses good steel so I think I prefer the thinner  for better access.
Also Knipex makes a quick set version in the 250 size. That slides closed like the NWS.
These are great! Cut hard wire up to 4mm. Mild steel up to 5.2mm with a very compact tool.
Yeah, the Pliers - Wrench is nice too!  They have recently added a bent/ angled/ offset version to the line.
Thanks to this post and [member=57948]ChuckM[/member] , I was at Menards last night and just had to pick up a pair of these. I especially like the thin jaws  [thumbs up] and the self locking feature.  [cool]
The jaws are less than 1/4" thick, .235" actually.
I already have several of their wire cutters so this was an easy decision.
I have had a pair of the Knipex slip joint (If you can call them that, since they lock?) pliers since around 1997. They were used almost daily and are still my go to pliers. Barely any wear on the teeth, nor the soft grip handles, which shows how high of quality the steel is. On par with Snap-on, which I rarely will offer as a comparison.
I agree with you Michael Kellog!  I love these little cutters.  Just used them this morning to cut some little bolts...
Trevin
i also have a knipex habit at this point, all excellent, but the wrench pliers are by far my favorite pliers.
NWS do some very nice compound action end cutters, great for snipping nails upto about Paslode framing nail thickness (3.1 mm if I remember right)
Also VBW make some pliers and snips of excellent quality.
Both German companies if that makes any difference.
Got the two big ones today plus a couple Wera items.  [smile]
Cheese said:
Couldn’t resist the urge, could you... [poke]
    Nope.
    Headed out to work on the water main now  [eek]
I like Knipex for water pump pliers and their pliers wrench but prefer NWS for electricians type pliers, they just feel better in my hands.  Both are high quality and are worth the price if you use them and/or appreciate good tools.
