Laguna 1412 Bandsaw Deal - Ultimate Tools
Ultimate Tools Marketing
Festool Dealer
Hello Canadian FOG
Laguna 1412 Bandsaws are on sale for $1999.00 and come with a free bandsaw blade.
Features include pyramid shaped spine for rigidity, 1 ¾ HP TEFC Motor to resaw 12 inches,
quick release tension, 115 volt outlet for accessories and micro polished 21″ x 16″ table
mounted onto oversized trunnions, paired with an aluminum hi/low fence. Solid cast wheels
are electronically, dynamically balanced & fitted with polyurethane one-piece tires designed
to run cooler & last longer than conventional tires.
The worm gear & pinion is ultra-smooth
and engineered to have minimum flex even when fully extended. This is a trade mark of
Laguna, just like the famous ceramic Laguna guides. Double windows allows you to check
both tension & tracking while the machine is running.
We have 8 in-stock for this price. Laguna is increasing price Jan. 1/2023
If you're considering a Laguna this is a good opportunity to get it.
Check it out here.
