jmbfestool
I much prefer timber beams over steel beams. I think they are better!!
biomedfred said:Is there any deflection in the center of the beam? Seventeen feet is quite a span. As a general question, and hopefully I don't cross a line on a woodworking forum, but at what point do you use a metal beam as opposed to wood?
JoggleStick said:Funniest thing with steel beams is when the fabricator misreads or misplaces little things like decimal points...
I had ordered a 1930 mm long I-beam with 100 mm welded flat bolt flanges at both ends...
I got a call from dispatch wondering if I was going to pick up my 19.3m beam or should they organise 'special delivery'...
All was well- they had rung me pre fabricating because the quoted price appeared a little low!!! ;-)
Sry to our US mates if the humour gets lost in the metrics... It's kinda like ordering a 6 footer and getting a 60 footer delivered....
Deansocial said:If anything you can allow mistakes with steel more. If its cut short it just a case of welding back on
Guilliaume woodworks said:..maybe not the perfect place for it ,but in this situation it's not in a bad spot.
