ear3
- Jul 24, 2014
Was trying to think of Xmas gifts for my Dad -- he's at the age where giving him more stuff is just gratuitous. But since he remains an avid reader in retirement, I thought I'd make some styled bookends, and create yet one more opportunity to do some wood shaping.
I've really gotten into shaping wood. There's a lot of spontaneity to the process -- I just draw a shape and let it slowly emerge from the block, no need for precise measurements. And its also tremendously forgiving -- if you gash the wood or catch an edge with the grinder you can just smooth it down. A little while back I was going to get a RAS 115, but everything has worked out so far using my M18 Milwaukee angle grinder.
To make the ends I laminated 6 pieces of 1x6 maple, which I had pre-cut with the rough curve of the piece using the Carvex. I would have glued all the rectangles and then cut them on the bandsaw, but this would have exceeded the capabilities of my crappy Ridgid bandsaw (hopefully I can upgrade in that area soon).
This is what the block looks like uncut -- next to it is the first one I finished yesterday:
Having the MFT was along with the clamping elements was really essential to hold everything in place as I was working the block into shape:
[attachimg=2]
[attachimg=3]
[attachimg=4]
The cutting didn't take that long, maybe 30-45 min per block. What took most of my time was the sanding. I went from 80 to 400 without skipping any grits, using pencil marks to make sure I'd done a thorough pass. Used the Rotex 90 mounted with the interface pad, sanding the curved parts in aggressive mode and the flats in RO. The most challenging part was getting the edges without producing too much of a rounding-in effect. After 400 went to 800, and then to Platin 2000. I paid a local dealer a visit early this morning to see if I could get some 1200 and 1500, but he doesn't stock them. The Platin definitely gave me extra gloss, though, even when skipping from 800.
I was actually unhappy with the first one (still some squigglies and blotches), and so I stepped back down to 220 and redid the progression, this time vacuuming and wiping thoroughly with a cloth, using a separate cloth for each grit. I've never been so anal about a process. This second effort was better, though not yet perfect. I still have a lot of work to do when it comes to sanding/finishing.
Finished it off with three coats of Renaissance Wax, buffing out with the lambs wool pad for the RO150. I found I got better results applying the wax with the RO150 felt pad than with just a cloth.
I'm pretty happy with how they turned out -- even got a small, fortuitous spot of quilting on one of the pieces of maple.
[attachimg=5]
[attachimg=6]
[attachimg=7]
[attachimg=8]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
[attachimg=8]
