My current home is a daylight-basement rambler with the shop down stairs. If I had a more accessable shop, I may have gone with more 'traditional' tools. Glad things worked out as they did -- I love my Festool system. So, in addition to working on house plans, I will be making decisions on the size, shape and construction of a new shop.
The neighboring property (which I just missed buying) has a home and a 30'x40' shop. My first thought was that I would probably want the shop at least 30'x44', such that the front half could be used for additional garage space with the shop behind. Additionally, I was thinking of having a slab floor for the garage portion with a wood floor in the shop -- we'll see... But, in determining a workable size for the shop I will need to consider the layout of the major work and storage areas.
My MFTs are as much the center piece of my current shop as a cabinet saw would be in many other shops. The biggest change for my new shop will be to have more perminate setups so I will no longer have to tear down one setup to create another. Currently I use one 1080 MFT as the main table -- my (Incra) fence is mounted to this table and each guide rail's hinged bracket is mounted to this MFT. A second or second and third table are added to extend the cut line, if you will, such that I can swing a 75" or 118" guide rail with these additional setups and leave the fence intact. You might picture this setup as a "T", with the fence along the top and the cut line as the horizontal part -- need to make a longer cut, just add another table to extend the cut line as required...
In the new shop I hope eliminate the teardown/setup between the different combinations. With more space, I will want have these different table combinations set up side-by-side to utilize the same fence system with a separate stop calibrated for each station. So, rather than a super-sized MFT, I will continue with the combo approach -- just won't be rearranging as much -- or at all.
Anyway, so much to do now... Delayed meeting with architect last week due to recent events, but hope to meet with him next week so we can get started on our next journey.
Corwin
