jmbfestool said:4. Markings along the rail would be handy. You can have a couple stops front and back you place where you want! So you marked out your cut out like a sink on a work top...... You place your rail on it you can marking near the splinter guard which run across the rail you can place your stops on the marks start and finished and you then just simply cut. Pick the rail up place it on the other side on the marks and cut again.
JMB
jmbfestool said:Are you Bored Alan?! Starting all these random topics which you know will be most likely start a massive debate lol
Well
I would like to see A new rail system to be honest but the New TS55 would still be backwards compatible to the old rail.
This would allow for more features to be added LIKE!
1. Anti tilt so you dont have to worry once you let go the saw drops of the rail!
2. Using your CT vac to create suction on the rail so no clamps need for certain applications. Once you stop cutting vac shuts down and rail can be lifted off
3. A second track closer to the splinter guard for clamping smaller stuff when needed
4. Markings along the rail would be handy. You can have a couple stops front and back you place where you want! So you marked out your cut out like a sink on a work top...... You place your rail on it you can see the markings near the splinter guard which run across the rail you can place your stops on the marks start and finish of the cut and you then just simply cut. Pick the rail up place it on the other side on the marks and cut again.
Few more things but gotta go add them in a bit!
JMB
jmbfestool said:4. Markings along the rail would be handy. You can have a couple stops front and back you place where you want! So you marked out your cut out like a sink on a work top...... You place your rail on it you can see the markings near the splinter guard which run across the rail you can place your stops on the marks start and finish of the cut and you then just simply cut. Pick the rail up place it on the other side on the marks and cut again.
Charimon said:jmbfestool said:4. Markings along the rail would be handy. You can have a couple stops front and back you place where you want! So you marked out your cut out like a sink on a work top...... You place your rail on it you can see the markings near the splinter guard which run across the rail you can place your stops on the marks start and finish of the cut and you then just simply cut. Pick the rail up place it on the other side on the marks and cut again.
Incra Nylon rules slide in and stay in place and allow you to place stops at defined distances, If you have the rapid clamp set use the front stop to make a "0" stop on the underside of the rail![]()
I originally put the rule in to make fluted trim
Rick Christopherson said:I hear people bringing up the Makita anti-tilt feature quiet often. What many of them don't realize is that this feature serves a purpose only when you are not using the saw. It stops the saw from falling over if you walk away from it. It doesn't serve a purpose during the cut. That's because if you let the saw ride against the anti-tilt rib, your bevel angle will be off. The absence of downward force on the rail will make this worse in the middle of a long cut. Knowing the way that Festool engineering thinks, I suspect that this is the reason why they have never incorporated an anti-tilt feature.
Deansocial said:Rick Christopherson said:I hear people bringing up the Makita anti-tilt feature quiet often. What many of them don't realize is that this feature serves a purpose only when you are not using the saw. It stops the saw from falling over if you walk away from it. It doesn't serve a purpose during the cut. That's because if you let the saw ride against the anti-tilt rib, your bevel angle will be off. The absence of downward force on the rail will make this worse in the middle of a long cut. Knowing the way that Festool engineering thinks, I suspect that this is the reason why they have never incorporated an anti-tilt feature.
yeah but i wonder how many people have droped a saw due to the lack o this feature, i know i have and it cost me a new bevel gauge as a result.
Quercus said:Excuse my ignorance but why the fascination with anti-tilt, just hold the machine while the adjustment is made. I tried the new TS55R at eco-build and it is good.
Alan m said:maybe the next ts caould tilt in wards so that the weight is still over the rail.
