I received a free sample of a Level 5 cut gloves. This is the highest rating for an ASTM or ISO cut-resistant glove. You are supposed to be able to press down on a razor blade with 7.7 pounds of force without cutting through the fabric.
It is surprisingly flexible and light. About as thick as cotton gardening gloves, but with a much tighter fit.
I have not worn them long enough to determine how warm they are going to feel using them indoors in the shop.
But for short periods of time, it certainly will be wearable.
Where would you use these? It will not protect against a table saw blade or a router bit spinning at 20,000 rpms.
When I was a picture framer, this would have been handy when cutting glass. I always deburred the edges with a glass deburring tool (sort of like a knife sharpener with the carbide set at 45 degrees instead of at a knife edge. So handling the glass after cutting was not an issue. It was only during the cutting and deburring operation was it required.
The gloves seem to be useful, but where? And how?
