Does anyone have any instructions or tips on leveling out a CMS-VL? I've never been happy with mine, but adding an incra positioner raised another issue, the VL sits higher than the MFT. I assembled the VLso long ago that I can't remember if those anchors that secure the VL to the MFT are adjustable in any way.
Beyond that, the entire top of the CMS is a collection of parts that are not co-planar. The inserts around the router shaft sit lower than the "router plate", I think can deal with that by not applying pressure directly over those inserts. But the frame around the removable router plate and the plastic trim pieces on the edges aren't level so sliding stock across the surface results in catch points in certain places. If possible I would like to address all of these issues.
