low profile dimmable cabinet lighting
Lighting
  • What works
    Votes: 1 100.0%
  • what doesn't
    Votes: 0 0.0%
  • Total voters
    1
obdoor
I've got two built ins to produce , one an entertainment center and the other a large work station . They are wood painted white and I need an under shelf dimmable accent lighting in each. What would you sugest ? What has worked for you and what hasn't ? Also , who is the best choice for procuring them ?
The premium LED strips from environmentallights.com are nice dimmable units. They make nice task lighting. Their customer service is good too. Very low profile, long life and pretty much zero heat output too.
I went with the strip lighting from environmentallights.com for a built in display cabinet I made.  These LED's are mounted on an adhesive backed semi flexible strip of plastic.  You can cut them to any length.  I went with the diimmable daylight white version for my cabinet.  I hardwired the LED's into a wall dimmer.  I liked these over the puck variety since they provided consistent illumination across the entire cabinet.
John
