oneinch said:
Wood_Junkie, Did you successfully mate your 618 to the Festool system? I was wondering about this very combination. Thanks.
No, I did not get it to work (well). Just as a follow-up to my earlier post above, I did wind up getting the mid-tier LR32 kit, with the sled, side stops and edge stops. I purchased the LR32 plastic insert to hold this stuff in a spare Systainer I had, and got a Whiteside 5mm spiral bit.
I also recently got the LR32 rail connectors, via an overseas chum. They are handy (in my mind) to have, although I haven't
yet put them to use.
Anyway, as to the LR32 experiment:
I drilled the holes in the LR-32 sled, to match up with the DW618 router body (this took some precise geometry). And attached it! ...
... And then realized that because of positioning the screws holding the DW plunge base would be scraping along the guide rail, which eventually would cause some rail damage, and putting the router off level (rocking on the screw heads). Since the sled is just sheet steel, there isn't enough material to countersink the screws. And the DW router base is webbed, not solid, so there's really no where else to tap new screw holes. And because of the size of the DW plunge base, there isn't a lot of option for rotating the base to fit in another orientation, unless you give up on having the bit centered in the LR32 sled.
There's no getting around it that I could think of. Unless you want to cut off the hold-down bolts on the LR32 sled. That'd give you some more options for rotating and aligning the router base for a bit better advantage. But I still don't think it would work and would have seriously ruined the LR32 sled. The Festool routers attach to the phenolic footings that serve as screw anchors, and they don't tear up the guide rail.
So, I figured it was an omen and picked up some Festool routers. ;-)
The OF1400 fits pretty well. The OF1010 fits *perfectly*!
