LS130 not abrasives
Lettusbee
I just purchased the LS 130, and wanted to get the full range of net abrasives for it.  However I don't need a 50 pack of every grit, which is what festool products.com has available.
Is there an alternate source where I can get possibly 10 of each grit?
Sent from my SM-N960U using Tapatalk
Mirka sell their mesh abrasives in the F/Tool Duplex sander's size:  81 x 130mm.  Abranet (good) in 80-600 g, Abranet Ace (better) in 80-400 g, Abranet Ace HD (best) in 40-120 g.
They're available in tens, 50s & mixes (usually made up by retailers).  While you're at it a handful of Pad Protectors might allow a bit more lifetime from those hideously expensive profiled pads.
I've never heard of FestoolNirvana, but ordered the Granat Net variety pack and a couple of the pads last night.
Thank you for that.
Did not realize Mirka had options.  I may order some of theirs as well to see which I like better.
Sia (Swiss manufacturer) also makes mesh abrasives (Sianet) in the same sizing.  Couple of grades, with Sianet 7900 the equiv. of Abranet, & the ceramic abrasive coated Sianet 7500 the equiv. of Abranet Ace.
Quantities are unknown.  I usually buy in boxes of 50.
