Ok, I have read posts of others buying and using CMT bits. Those that are can you post the exact model # of the bit. I can only find bits with a 8mm shank as the following 306.50.11 & 307.50.11 the problem is the #306 is 55.5mm long which is fine but the cutter portion is only 30mm compared to the Mafells 40mm. the #307's have the 40mm cutter length but are 65mm overall and stick out of the front of the DDF40. I made them work by cutting down the shank but if someone knows something I dont please let me know. The CMT's work fine but Im not a fan of cutting them down. Its a fine margin of getting them to fit behind the front of the machine and leaving enough shank to fit well.
