Rutabagared said:
Matt,
Not sure I follow. I can see that all lumber (project and domino) would be near the same moisture content. But shouldn't the domino cutter still cut the same width mortise regardless?
I meant that I presume July will be more dry than now, hence wood should contract. Domino's are already cut, but will probably be different wood and moisture content to what is being joined. If you cut your mortise now with a domino, I would expect it to shrink a little by July as the wood contracts with decrease in moisture. If you wait till you are just about to fit the domino and cut then, you will be cutting into contracted wood, so it should fit.
It all depends of the differential rate on contraction between the domino's and the wood you are joining. I have found the domino's to be very stable in size in my garage, and have had no problems year round with fit. Like others say, pop the domino in the microwave.. it will shrink it a little.
