Makita BHP459 18v Chuck Replacement
Locks14
Looking for a new chuck to upgrade the one that came with the tool. Any recommendations for a 13mm keyless chuck?
Rohm makes a nice almost all metal single sleeve keyless chuck. I believe the same chuck is also sold by Metabo, and may actually be manufactured by them. I believe Bosch sells a version of the same chuck too.
The older Milwaukee cordless drills came with an all metal single sleeve keyless chuck made in Japan by Yukiwa. I believe the Yukiwa made chucks were only sold on Milwaukee drills in North America. In Europe I think Milwaukee used the previously mentioned Metabo/Rohm chucks.
Between the two manufacturers, the Yukiwa chucks appeared to have a thicker more durable exterior than the Metabo/Rohm chucks. The Metabo/Rohm chucks may have had a better ratcheting mechanism to tighten the chuck. I've also run into older Yukiwa chucks that looked the same as the ones used on the Milwaukee drills, but with had a ratcheting mechanism that wasn't as functional as either the later Yukiwa version, or the Rohm/Metabo chucks, so be wary of old stock, although I don't think Milwaukee branded ones would have the problem.
Carbide jaws are also nice and preferred.
This is the Rohm chuck I'm referring to.
http://www.amazon.com/Rohm-893352-Extra-RV13-Through-Hole-Diameter/dp/B00DD7KS5O/ref=sr_1_1?ie=UTF8&qid=1431513305&sr=8-1&keywords=Rohm+chuck
This is the Metabo chuck. I'm not sure whether it has carbide inserts. It's the Futuro Top S1M model.
http://www.metabo.com/Product-catalogue-accessories-handheld-powertools.24046+M5f91011d361.0.html
The Milwaukee chuck I'm referring to is the one pictured on this drill. I'm not sure whether it can still be purchased separately.
http://www.amazon.com/Milwaukee-0302-20-2-Inch-Drill-Keyless/dp/B00005Q7AH/ref=sr_1_2?ie=UTF8&qid=1431513963&sr=8-2&keywords=milwaukee+keyless+chuck
Rohm also manufactures a single sleeve version of their Supra SK chucks. I believe it is/was used on the top of the line Dewalt drills. It was heavier construction than the previously mention Rohm chuck.
Thanks for the info. I found that Rohm chuck for £65. Then found exactly the same chuck sold as a Dewalt part (even has the Rohm stamp on it) for £16 so a happy and less costly upgrade.
Many thanks!
