Heathwarren
- Dec 12, 2022
Crazyraceguy said:That looks really nice. I love the minimalist look, but the TV actually sitting in it, makes me a bit nervous.
There doesn't seem to be any center support and that can lead to sagging over time and maybe even wobbling?
The top material is pretty thick, but the span is very wide too.
I hope I'm wrong, because I really like the look.
squall_line said:Crazyraceguy said:That looks really nice. I love the minimalist look, but the TV actually sitting in it, makes me a bit nervous.
It appears to be a Samsung Q70 series TV, which runs around 55 lbs in the 65" size.
I put the following into the Sagulator:
55 lb total
Center load
Fixed (Side attached)
60 inch span
18 inch depth
Black walnut
No edge treatment
Total sag: 0.02 inches total, "Acceptable"
At 72" span, it increases to 0.04 inch total sag, also "Acceptable"
I really wish manufacturers had multiple stand options for each TV; last time I upgraded my TV in 2016, I had to buy an entire new stand because the TV had the little feet spread wide by the ends and the feet were wider than what I had available at the time for my stand. My newest TV has a center base similar to this one, which is much heavier than the wide-stance feet. I just ended up wall-mounting my new TV, though, since I had a rather awkward center channel speaker to fit under it.
luvmytoolz said:squall_line said:Crazyraceguy said:That looks really nice. I love the minimalist look, but the TV actually sitting in it, makes me a bit nervous.
55 lb total
Center load
60 inch span
18 inch depth
Black walnut
No edge treatment
0.5mm deflection from a 55lb TV just doesn't sound real world figure to me?
squall_line said:luvmytoolz said:squall_line said:Crazyraceguy said:That looks really nice. I love the minimalist look, but the TV actually sitting in it, makes me a bit nervous.
55 lb total
Center load
60 inch span
18 inch depth
Black walnut
No edge treatment
Too little or too much?
A static load on a solid piece of 4/4 walnut shouldn't produce much deflection. The individual board itself probably outweighs the TV.
luvmytoolz said:squall_line said:luvmytoolz said:squall_line said:Crazyraceguy said:That looks really nice. I love the minimalist look, but the TV actually sitting in it, makes me a bit nervous.
55 lb total
Center load
60 inch span
18 inch depth
Black walnut
No edge treatment
I'm thinking it will deflect more but I could be wrong, but the TV is the weight of a bag of cement with roughly the same weight distribution area, so for a 1" thick board supported at the ends, only 0.5mm deflection seems optimistic?
Heathwarren said:luvmytoolz said:squall_line said:luvmytoolz said:squall_line said:Crazyraceguy said:That looks really nice. I love the minimalist look, but the TV actually sitting in it, makes me a bit nervous.
55 lb total
Center load
60 inch span
18 inch depth
Black walnut
No edge treatment
These are all great observations. The wood is 13/16 but I added some insurance. There is a vertical brace in the center that runs from the back edge forward about 6 inches. It forms a t shape, but only at the back so it isn’t visible. That’s where the bulk of the tv weight is. That way there is room to center the sounds bar.
