Measurements on Kapex Crown extensions
ear3
New York, NY
Trying to decide on whether to get some of the Kapex crown extensions for use when the saw will be mounted on the cart I'm making, and so for design/planning purposes, I was wondering if someone could give me some measurements -- that is, how much extra bed do each of the extensions provide, both depth and width (and for width: on its own, or as measured from the blade).  Thanks.
I hope these help. I noticed when I was done that the extensions are cut at two different angles where it meets the saw base, so I added pictures on both sides of the saw so you can see that as well. If you need additional photos or dimensions, let me know!
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
[member=18038]copcarcollector[/member] Perfect!  Thanks a bunch!
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
You bet. Also remember, you cant use the crown extensions and the UG extensions at the same time. Weird oversight on Festools part...
