I got the Starmix/Metabo vac, after my CT36 disintegrated and then stopped.
It’s a curvy little bugger, so getting a plate to fit the top is tough. Also, the Metabo or Starmix branded solutions are extremely expensive and only available in Europe (if you can find them in stock).
I found a Metabo trolley (630174000, METABO TROLLEY AS 18 L PC / METALOC) and removed the casters.
I drilled through the caster mount points (using the trolley as a guide) into the ASR top cover.
The ASR top cover is very thin and flappy polypropylene. I beefed it up from the inside using 3M panel adhesive, which when applied properly loves to bond to PP, and looks and machines like it.
I attached the trolley with long coarse threaded screws, driving them up through the ASR cover into the trolley’s caster mount points.
There’s a ton of skipped steps, caveats, and tricky points that I could elaborate, if anyone is interested.
I just thought this may interest fellow FestFools, as the Starmix vacuum is legit, and really has been a workhorse for me, and unlike Festool, it’s a tank capable of working outside, offroad, doing cement work.
