chrisrosenb
- Sep 1, 2007
We purchased a foreclosed home next door to us. The house is a ranch style & there is also a 3 car unattached garage. Both building lots of work. So we are starting at the top. The roofing on both buildings is 3 tab asphalt shingles & need to be replaced. I am considering using hidden fastener metal roofing.
I have searched & have not found the clear cut way to install it. The options I found were to put the metal directly over the asphalt shingles, or put foam fanfold insulation over the shingles & put the metal over the insulation. Other options are to install furring strips over the shingles & put the metal over the furring strips, or remove the shingles, lay felt paper & put the metal over the felt paper.
I am open to suggestions.
