Metal Sonic Blade in TS55
Kev
I had a one off need and decided to get a "cheap blade" to do the job. I needed to trim a few mm off the bottom of two garden shed doors (All of my serious gear is packed away so deep for moving that buying a blade for my easily accessible TSC55  seemed prudent!)
[attachimg=2]
[attachimg=3]
Obviously garden shed doors are thin, cheap things but I was still extremely impressed with the blade .. I could have been running it through a sheet of paper for all of the resistance it offered and there were minimal sparks. I've got no idea about the longevity of this blade, but if you have a smallish job I wouldn't hesitate. I could have easily done the same with the HKC55.
I paid $77AUD for this blade and that's less than half the price of a similar purpose FLAI.
I'm quite impressed [smile]
Thanks for the review.  Seems like the way to go for rough work.  Good luck with the move and enjoy unpacking the serious gear!
Bohdan said:
How does the blade compare with the Festool ones when cutting wood?
[member=36526]Bohdan[/member]
I haven't tried to cut wood with it yet, I can only hazard a guess that it'd be quite a good crosscut blade from what's obvious .. so much so that I'll probably grab one for the cordless Metabo SCMS.
The blurb on the saw says ...
WOOD - Clean cuts in all wood sections. Gives very clean cuts in laminates and Particleboard/MDF. For use in miter saws and portable tools.
From the local distributor ...
http://www.centralsaws.com.au/products/byhierarchy/21/63
For the TS55 I got the 160mm 20mm 40 tooth variant ...
http://www.centralsaws.com.au/Products/339/63/MSB16020402
