MFK base storage
morts10n
MFK comes standard with vertical base and 3° base. Is there a way to store a zero degree base in the systainer as well?
If so maybe add a pic
I'll have a look tonight at mine to see, but I found this insert pic showing an empty slot for a base at top left, it's possibly a slightly different layout to mine, but maybe it helps you.
The supplied base is not 3 degrees, it's only 1 1/2 degrees. Beyond that, I have never seen an insert that can hold a third base. The main body will fit with either of the bases attached, with the other one in its place.
I have always kept mine behind the Systainer, on the pullout.
Correct....not 3 but 1.5°. Only have had mine for a few months
Just because the inlay wasn't designed for it doesn't mean it won't fit in the Systainer. People store all kinds of stuff in the Systainer that just happens to fit well despite the inlay never having been designed for it. Like the FS-WA/90 in the TS 55 Systainer.
Not pretty, but it works for me. I don't have the edge guide that is designed to go in that slot.
