MFS 400 ?
Tom R
What is the smallest circle the MFS 400 can cut with a OF 1010 router?
Please advise,
Tom R
Accurately: with a 1/8" up or down spiral bit in the circle routing insert: 82mm or 3 3/16" diameter.
Not accurately: With a 5/16" template guide held next to the side of pivot guide with a 1/8" up or down spiral bit: 23mm or 7/8" diameter
Tim
Thank you for the reply
I have to make several small circle cuts ranging from 72mmm - 94mm, accuracy counts. I am considering the MFS 400 or the circle gig from Micro fence. I believe the MFS
may be a more versital tool but the Micro Fence with the lift kit will be accurate and repeatible. I needed some input from someone who was familiar with the MFS 400
Thank you for the information
Tom R
Mr Tim,
I was leaning towards the Micro Fence, just need more info - Festool does not publish enough specs
on there tools, need user input.
Thanks,
Tom:
As Brice Burrell recommends, if you are thinking of buying the 400 also buy the 700.
You will find you will use these things everywhere.
Tim
I love my 400!  I hardly ever use it for it's intended use - with the router.  It's a perfect oversized square and it also acts as big flag stop for making repetitive cuts on my MFT.  I simply butt it up against the fence and use a quick clamp to hold it in place where I want it.  I can think slide my stock under the rail and butt it up against the MFT and quickly make several identical parts.  Don't know what I would do without it.
