jonny round boy
- Jul 21, 2007
I recently did a job which required a stepped opening cutting into a solid timber worktop to fit a Miele flush-fitting induction hob.
[attachthumb=1]
I used my OF1400 with the guide rail, and whilst I was happy with the finished cut-out, it took a good couple of hours to do (mainly due to taking time to make sure rails were correctly aligned, start/stopping points correct etc - I didn't want to make a mistake!).
I've now got another, similar situation, only this time it's a piece of granite (700x500x20mm) to set in. It occured to me that it would be much quicker to do it with an MFS, but it's a lot of money to spend - I'd need the larger MFS700 set plus an extra set of 1000 rails, so that's well over ?400 ($800) worth! One thing that offsets that cost slightly is the thought that I could use the MFS template & router for all my hob/sink cut-outs, in both solid and laminate worktops, instead of the TS55/jigsaw combo (the idea being just set it to the right size, clamp down, and the whizz round with the router in 4-5 passes).
Has anybody used the MFS for this? Is it actually quicker to do them this way?
I know if I bought it it's one of those things that you'd always find other uses for too, but the initial cost is quite steep...
To try & help me decide my local dealer has ordered one of the smaller MFS400's in for demos, so I should be going over there in the next week or two to have a play with it.
[attachthumb=1]
