I need a replacement top for a MFT 1080. I have found a local CNC shop that can do the work at a reasonable price (less than it would cost for any of the jigs to make a top) but I need a DXF file to provide to the fabricator. TSO has a set of DXF files and the one listed as "similar" to the MFT 1080 produces a table that is 1321mm x 736mm while the Festool spec sheet for the 1080 says 724x1164.
I guess I can trim to fit the table but there might be some wonky placement of holes, have not figured that out yet. In the mean time, is there a CNC file somewhere that gives an exact replacement top for the MFT 1080?
