MFT/3 Accessories?
NHSP759
Hey guys, I just got my new MFT/3!  Wicked stoked!  Anyways, I bought a some clamps from Festool and read that B&D makes some bench dogs that work with the table and ordered them. Anything else you guys can think of that I can use on the table in the aftermarket realm? Thanks
To go along with your bench dogs you should seriously consider rail dogs.  This will allow you to make perfectly sqare cuts using your track saw.
I personally use to ones from Precision Dogs.  Light weight, fits perfectly in holes.  Add to that top notch and speedy customer service.  http://precisiondogs.us/products/precision-rail-dogs
Danny
Thanks for the quick response guys. I checked out both sites dna am definitely going to get the dogs. As far as the Kreg goes, and I have the pocket hole kit and have used it for a couple of years now, does the rail have an adapter kit or do I have to route a mortise in the top to attach it?
People use a knob from a clamp element. They swap the bolt for a longer one.
Kevin
The Kreg Automaxxs work well with the Presicion  Dogs, use a clamping knob with a 1 1/2" 5/16"-18 thread (most machine tool suppliers (MSC for ex ... bought some of mine mine from Grizzly,I also made some using a knob with female threading and a piece of threaded rod from my local hardware store).  I also use an acrylic round off fault from a hole saw on top, under the clamp, cut to distribute the load.  Put the dog through from underneath the table.  These clamps are amazing I use them on my drill press in a length of 8020 1545 extrusion held in my machinist quick clamp.  They clamp anything from 1/4" to 2 1/2" with no adjustment.
