MFT/3 Front of Table Extension = Flush Guide Rail
This front of table extension is 2 pieces of MDF glued and pinned then fixed to the MFT with 3 t-bolts. It makes the guide rail flush with the front of the workbench so you can't bump it out of square or catch loose clothing on it. There's a block of wood that makes a very snug fit when the guide rail is pressed down and again this will prevent clothing getting snagged on the rail. I have grazed my MFT profile when using a jigsaw - this can not happen now. The whole thing goes on and comes off very quickly and gives a bit of extra worktable that overhangs the MFT profile.
I use the Kapex crown moulding support to extend the MFT. I purchase them used so the price is not that bad.
If that setup gets any bigger it's going to need its own bathroom!
What are you processing regularly that needs that much surface?
Fitted furniture such as bookcases, cupboards, shelving units - anything up to 8' tall. Mostly the joinery method used is dado and rabbets hence the many flag stops that makes it very quick, straightforward and accurate to do multiples.
(quote)
I've tried the Kapex UG stand extensions as an MFT/3 table extension, it's okay, but these shop made extensions attach far easier than the UG - the locking knob doesn't tighten fully as it hits the MFT profile. Also they're not very wide as they were designed for use with a mitre saw where as this set up is for sheet goods.
Dirt cheap to make, easy to install and remove, very stable in use (though these are bolted to a substantial and heavy trolley) very easy to get flush with the MFT surface and they increase lengthwise capacity to as much as you'll ever need...
(quote)
No argument from me. I make various "accessories" for the MFT. Currently I have the paper dereeler on 3 of my MFT 3's. This allows me to easily cover the tables and move the "dirty" area out of the way.
All of this came about because I wanted to put a handle on the front of my MFT cart so I can move it easier as this thing weighs a ton...
I am working on my own MFT3 table extension.  Do you buy the T Bolts from Festool or just from a hardware store?  Any specific specifications?  Do the knobs come with them?  (Sorry for my ignorance.  I am new to woodworking.)  :-[
Thanks!
The t-bolts I used were from Axminster in the UK and came as a 40 piece set, but anything similar will do.
Hi thanks for sharing.
Did you connect the two MFT's together?  if so did you just use Festool MFT connectors (484455)? or another method?
thanks
Stan
The MFT/3s do have the Festool connectors on them as they do a good job of aligning the tables. There's also a hardwood block inside each foot that's screwed to the MFT through the hole the original legs were bolted through to keep it all locked down and solid.
The MFT/3 (or 2) is brilliant when it's on a very stable base. Cuts stay square. It's also very easy to modify to make as big as you'll ever need with the t-track in the side profiles. I love them...
