RobWoodCutter
- May 16, 2010
Just bought two MFT/3 tables to setup along side my L-N workbench. The MFT/3 is about 1-3/4" higher than the workbench.
I am going to cut the legs on the MFT/3 to make it the same height as the workbench. (Don't care about warranty or resale value, when the time comes to replace or get rid of it, it will be given away.)
My questions is the adjustable leg has an insert. I see on the parts page I can get a replacement insert if I mess something up.
Is the insert glued in to the leg or is it just a friction fit and do you know how far into the leg it extends?
If it only extends into the metal leg and 1" or so, I don't need to pry it out first before cutting the leg. If it extends more than 1-3/4" and it is not glue, I will try prying it out before cutting the leg shorter.
Thanks. Rob
Thanks. Rob
