MFT/3 Table Extension - Provides 33% more working surface area!
TSO_Products
Retailer
Maximize your workspace with this seamless addition to your Festool MFT/3 Multifunction Table: the TSO Extension Table for MFT/3. With a flush-fitting design, this extension utilizes three precision machined brackets that quickly lock into the MFT/3 perimeter extrusions to provide a rigid, seamless extension of your worktop. The MDF top is CNC-machined and shares the same 20x96mm hole pattern as the MFT/3, ensuring compatibility with all of your workholding accessories. This extension can be mounted to any side of the MFT/3, but we prefer it mounted on the right extrusion to provide much-needed support for offcuts while track sawing. Whether you're sawing, routing, sanding, or assembling, this extension provides the additional surface area needed to support your materials and tools.
Key Features
  • [size=16pt]Large top measuring 28.2 by 15 in. (716 by 381 mm), providing 33% more MFT/3 work surface area
  • [size=16pt]Three precision machined brackets for fast and rigid connection to MFT/3
  • [size=16pt]Gusseted support design keeps your floorspace open and clutter-free
  • [size=16pt]Attach to any side of your MFT/3
  • [size=16pt]Shares the same 20x96mm dog hole pattern as the MFT/3, ensuring compatibility with accessories
  • [size=16pt]Pre-chamfered dog holes compatible with Chamfer Dogs, TDS-13 Dog Stops, MTR-X Precision Triangle, and other accessories
  • [size=16pt]Easy on and off for maximum versatility
[size=16pt]See It In Action! (Click the image below to watch our launch video.)
[size=18pt]Learn More About the MFT/3 Extension Table
Oh, By the Way...
We've also launched a Compact Router Table Extension for the MFT/3 using the same durable, rapid on/off bracket system as our router table! The flush-fitting design enables you to use the large work surface of the Festool MFT/3 as router infeed/outfeed support. Compatible with the most popular trim routers on the market, this compact router table is perfect for profiling edges, cutting dados, flush trimming, CNC tab removal, template routing, and other common trim routing operations.
[size=18pt]Learn More About the Compact Router Table Extension for the MFT/3
What else is happening at TSO?
JUST RELEASED! GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
