MFT/3 table top finishing
Slowtee
Just received my MFT/3 and was wondering should I clear coat the mdf table top to protect from humidity. Also what would be the recommended top coat?
Tony
I've clear coated one top I made from mdf. I used General finishes high performance top coat in Satin. It's held up really well. When I flipped over the top on my mft I had a bit of a can of Osmo Polyxx Oil left over so I coated it with that. The good thing is that it added a sort of grippy feel to it. The bad is that it gets down in the dog holes and if you don't ream those babies out with a dog the day after you coat it, it will be hard to get dogs in some of the holes.
Sent from my Pixel 3 XL using Tapatalk
I used shellac on my MFT tops. Durable and easy to repair. Din't mess up the dog holes either (sprayed).
Jack
I've found OSMO Poly x oil to be very effective, I like the way it soaks into the surface rather than on top like varnish etc.
Another vote for the Osmo polyx (but not a vote against anything else)
I coated mine when I noticed that simply touching sweaty forearms on the mft top raised the surface a bit. The osmo makes a nice surface to work on that isn’t too slick. I removed my top and coated both sides, the edges and the holes. I didn’t find it adversely affected the fit of the dogs, ymmv.
imho, Festool should ship it pre-finished with osmo.
