Woodwork Wizard
- Oct 25, 2013
I realise this will be probably be of no use to anyone but for my use I thought it was a good idea. I was using a piece of 3x2 held to the MFT as the base for a RH table extension. I had to remove this 3x2 every time I wanted to use the CMS angle guide for anything less than 200mm.
What I did was to cut the 3x2 in to pieces to make 2 bases, now the CMS angle guide goes between them, so now swapping the CMS guide (photo 1) to the RH extension table (photo 2) can be done in about 2 minutes.
