dogutsukawu
- May 24, 2010
I enhanced my MFT (2 tables joined end-to-end) with 2 Incra incremental rails and stops.
[attachimg=#]
This enhancement builds parallel guides into the MFT, with all the advantages of the Festool parallel guide and more. The added benefits are due to incremental nature of the Incra rails and a "fence board" which spans the table and butts against the stops.
[attachimg=#]
The setup is as follows. Attach 2 Incra rails, one on each side of the MFT. Square the Incra rails to the guide rail. Position both stops at exactly the same distance from the cutting edge of the guide rail. Push against the stops a raw fence stock, 3/8" thick, broad enough to span the stops, and long enough to stick out beyond the cutting edge. Cut the fence. Set the scales on both Incra rails to read zero at the stops. Done.
Now if you set both stops at 20 mm, push the fence board against the stops, push the stock against the fence board, and cut, you'll cut the stock at exactly 20 mm wide and parallel, every time. Works for any dimension up to the length of the Incra rails (mine are 54").
With this enhancement, you get the following benefits of the parallel guide and more.
1. Cut stock square and parallel without measuring, marking, and aligning.
2. Cut two pieces to EXACTLY the same dimension on separate occasions (unlike the parallel guide where the stops are set by eye and not with the repeatable precision of an incremental positioner).
3. Cut wide and narrow stock with one setup (unlike the parallel guide).
4. Cut thin stock without shimming (the parallel guide requires shimming of stock thinner than the guide bars). Make sure the fence board is at least as thin as the stock.
5. Rip a piece narrower than the guide rail. For narrow ripping, the fence board is the same thickness, ideally, as the thickness of the stock. In practice, I've used one fence board (3/8" thick) successfully with stock of different thicknesses.
6. Cut narrow stock to length using only one stop, just as on a chop saw. For this purpose, don't use the fence board. In its place, use the aluminum extension rod supplied with the Incra stop with the rod zeroed at the cutting edge. With the parallel guide, it can be awkward to get the guide rail to sit flat on narrow stock.
7. Stays in calibration (square and parallel) once calibrated (unlike the parallel guide which may go out of calibration with use).
8. Make cuts up to 48" wide (with 54" Incra rails). The parallel guide is limited to about 24".
One more advantage: the setup is cheaper than the Festool parallel guide. However, the parallel guide works for ripping long stock, and it's portable.
[attachimg=#]
[attachimg=#]
