When I started down this slippery slope I could not justify the cost of another router. I have four, Bosch, Bosch trim, Dewalt, and PC. I was however, enamored with the use of the guide rail. Enter Microfence... I figured I could use the Microfence Festo Slide Interface and make it applicable to any of my routers. At first I was a little disappointed with the setup due to a small amount of slop in the UHMW piece that actually slides on the guide rail. Well I solved that today. I added two nylon tipped set screws to the slide (drilled and tapped two 8x32 holes). I am pleased to report the unit is quite rigid now. I also added two limit stops (491582) to the setup.
I hope the pictures work
