I don't think our posts will reach the OP - probably a dump and run...
However, other new MFT users might appreciate it.
I know I had a little bit of frustration at first when using the MFT. I was so excited that my wife bought me one and then so disappointed when my first cuts weren't square.
I watched a few of the MFT training/how to videos and spent a little more time familiarizing with how to square the setup.
I also added a bit of silicon tape to the tab of the rail guide to take out the slop.
That worked great and I was off getting square cuts no problem. Just check square often - especially when changing height, as someone mentioned.
The best decision after all that was buying the TSO GRS-16 PE. I purchased the newer version that it drilled and tapped to attach to the MFT rail holder. I tell ya, so much quicker and easier to use and still flips out of the way. With the GRS I don't have to mess around with squaring up the rail on the MFT. Just bump the piece up to the GRS and away you go.
Plus, it's pretty quick to pull the GRS off the table and use it when cross cutting larger sheets.
At first, I was frustrated that I 'needed' to spend more money. Now I just appreciate how nice of a setup it is.
And I'll still use all of the MFT accessories - the rail when I want to cut odball angles. I have Parf dogs if I want to cut 45's.
The Festool fence and the angle thingy are also handy when clamped to the right side of the MFT to use as a stop for repeat rips. I've used that to cut a bunch of narrow strips quickly.
The fun and frustration of the MFT is in the learning process. I think that's like almost anything in woodworking. Someone makes it look easy but it still takes time to learn any tool or method correctly.
