Here's a simple addition that will increase the utility of your MFT by providing secure, non-protruding attachment points. The change doesn't interfere with the usual use of the MFT in any way.
Disassemble the MFT frame and add nuts to the inside channel used by the corner bolts and also to the channel on the underside of all four sides. I'd use at least 2 per channel per side, and 4 or more would be better. These nuts will be captive after the MFT is reassembled but free to slide back and forth.
Use M8 square nuts if you're keeping it metric. 5/16-18 square nuts are also a good fit. Hex nuts do not provide as much clamping area or resistance to being turned.
Why would you do this? What use would it be? I say that the modification is so cheap and so easy when you're building your super-MFT, just do it.
