MFT Wing
This is designed for the older tables, but there have been a couple of threads here where people did some minor modifications to use it with the newer MFT/3 table
I've modified mine for the MFT/3. You basically just have to shim up the distance between the bottom of the out feed and it's supporting "L". You will also most likely need longer screws as well.
Exactly right BB. It will work with the MFT/3.
Thanks for the help, can some post a picture of what is look likes on the table.
