Midi I (bt) and CT VA (204083)
Tomsim
are this two now comatible or not, without changing conectors or maybe some other parts.. longer hose?
I saw a post here where the author says that it is needed to change the conecting adapter, 90deg to straigth.
On offical site in the picture there is already one side straigth connector.https://www.festool.com/products/dust-extraction/pre-separator/204083---ct-va-20#Overview
My Festool dealer tells me it comes with two 90deg comnectors. And that Midi is not made to be used with preseparator.
On amazon, i read it comes with additional conector, so it can be changed from 90deg to straigth, and that it works with midi out of the box.
I confused, so i’d be thankful if someone has the latest info about this.
Thank you
