T. Michael
- Jan 22, 2007
Hi, I'm transferring 3 posts from What size hose for my CT 22 topic where Toolpig wanted to hook up a table saw to his CT 22E. Corwin suggested I start a new topic, and I thought these three topics might get one going. Mike
I got the Clear Vue first, less expensive, direct to 2.25 vacuum hose right out of the box. But, one has to make an adapter to a 5 gallon bucket. So, fishing around the basement, found my wife's old beer making kit with a screw on lid to a 5 gallon bucket. ( she hasn't noticed it's gone yet).
It is way cool to watch the chips go round and round, then down. Some light one's just go round and round til you turn it off. Interesting. This one I have hooked up to a Lee Valley clear tube dust collection kit, plumbed up the the ceiling, with drops for my sanders over the work bench. Sort of a poor man's boom arm, but with three drops, and little gates. I hooked up a multi outlet extension cord so that it terminates at each vacuum drop. I can have two or three sanders plugged in at once, and each will actuate the vacuum -- in this case a WAP.
Also hook up the Domino to it, and that works great. But, as someone said I loose the anti static feature of the hose. No sparks and fires, but a little van de graff (sp?) generated spark goes from my knuckle to the hose coming out of the side of the Domino. Tickling, but irritating. May have to figure out how to ground that later.
Got the Dust Deputy a year later, after I got the CT 33 for the router table. That one is, so far, dedicated. DD makes one with 1.5" hose inleta and outlets, steel, very subtantial. The also offer a 2" model for an up lift to an already high price. But, it does come with the clampable 5 gallon steel bucket with a big O-ring around the lid. Bolt it together and you're almost ready to go. you have to figure out how to get form 1.5 or 2.0 inches up to 2 1/4"; standard shop vac and US CT hose fitting size. Dust Deputy sell their own hoses, but I chose to adapt to my nice Festool ones. Also lost the grounding feature because I used wood and plastic step up and step down hose adapters.
Like them both, Dust Deputy is more stable on the ground, (shorter, and wider) Clear Vue seems to have all the features of their big cyclones; angled input, long slim taper. And the plastic is tough. It's fallen over several times, no damage whatsoever. Both seem to catch a lot of chips.
I'll take pics tomorrow and post them of each system.
Hope this helps. Ask any questions of things I may have over looked.
Mike
Mike
