Mike Goetzke
- Jul 12, 2008
Peter Halle said:Frankly with all the bits and pieces I have always thought that the Systainer was a perfect example of why to buy the set. Last thing anyone needs is to get it out to use it after 4 months and find that a critical part has gone missing. I know that would happen to me. Others will differ.
This is the partial set. I got it and now see that as a mistake.Mike Goetzke said:I saw this for about 1/2 the price of the full LR32 system. Worth it?
mino said:This is the partial set. I got it and now see that as a mistake.Mike Goetzke said:I saw this for about 1/2 the price of the full LR32 system. Worth it?
Doing it again, I would get just the plate and the centering mandrel. Then I would use the TSO parallel guides to place the rail reliably, instead of the convoluted stops Festool includes. They are just too slow to use for repeat work.
In summary, yes, the savings are absolutely applicable compared to the "full set" and I would go as far as saying that you should get just the slide plate and put saved money into getting the TSO PG system to use with the plate per above.
I have my LR32 set permanently coupled to a mid-range router and the whole assembly is stored in a SYS 5 T-Loc.
Peter Millard has a couple videos on his "tuned" setup with some simple tweaks.
